DESPERATE! Need block for D-15, Series 1
Rodger VanDruff
09-15-1999 06:18:31
I'm looking for a short block for my D-15 gas tractor. Located in Southwestern Penna. Call during the day at [714] 627-5484.
GeneD14
09-15-1999 12:16:13
 Re: DESPERATE! Need block for D-15, Series 1 in reply to Rodger VanDruff, 09-15-1999 06:18:31
If it's the 149ci engine block, some of the D14's use the same one and are alot easier to find. If you get real despirate call:
Stamm 1-616-792-6204
Wengers 1-800-451-5240
Myers 1-219-294-1008
Wellerts AC Parts 1-330-262-6991
Good luck & happy hunting!
Dennis Schmelz
10-05-1999 20:46:14
 Re: Re: DESPERATE! Need block for D-15, Series 1 in reply to GeneD14, 09-15-1999 12:16:13
You may want to note that D-14's had a lower compression ratio than a D-15. The block should work OK though and a different set of pistons would take care of the compression problem. Good luck.
