CA Front Axle Seal Follow Up
phil(va)
12-29-2006 18:13:26
Some time back I posted a question about how to hold the front seals onto the axle to keep them from turning when the hub turns. For those who are not familiar with this issue, the front axle seals should remain seated on the axle and the hub rotates around the outside of the seal. In my case the hub was tight enough on the seal to make the seal rotate on the axle. I finally tack welded the seals onto the axle from the back of each seal. That fixed the problem. Just FYI for anyone who might be interested.
