WD Hyd Fluid Leak from Pump Linkage
Bob Russell
12-29-2006 04:10:54
My WD is leaking hydraulic fliud out of the pump around where the linkage rods go into the pump. probably needs seals. before I tear into it I thought I would ask how difficult it will be to replace the seals. any direction would be appreciated. Bob in Mo
old
12-29-2006 09:06:58
 Re: WD Hyd Fluid Leak from Pump Linkage in reply to Bob Russell, 12-29-2006 04:10:54
Can't help on the rebuild but if you find you need a new/used one I have one on a parts WD out back. E-mail is always open
Bo Russell
12-29-2006 09:52:35
 Re: WD Hyd Fluid Leak from Pump Linkage in reply to old, 12-29-2006 09:06:58
if it's a non leaker, how much do you want for it? Thanks
old
12-29-2006 11:46:31
 Re: WD Hyd Fluid Leak from Pump Linkage in reply to Bo Russell, 12-29-2006 09:52:35
Well when I took the engine out of it because of a broken PTO houseing it worked well and didn't seem to leak. Drop me an e-mail and I'll give you a price. I don't talk money on the forums
