WD45 Water pump
jared in wi
12-22-2006 13:48:34
I need to get a new water pump for a wd45 that i am working on for the neighbor. i did some checking, and found one from JD Parts that will replaces water pumps with casting numbers 125577, 9009248, and 108317. the only casing number on the pump that i took off of the tractor is 1191. my question is, is the pump that i took off the tractor the right one, or is that for another tractor? also where is the casting number located? just to make sure i have the right casting number.
Thank You in Advance
Jared
Texas Denny
12-24-2006 06:36:16
 Re: WD45 Water pump in reply to jared in wi, 12-22-2006 13:48:34
Jared, since it has been a couple of days and you've got no answer, I'll take a stab at it - though you may consider it feeble.
I don't know anything about casting numbers since my experience says they are the same for all WD and gas WD-45 tractors. And I believe there is no difference even on the gas D-17 and late WC's. y
However, I have never bought the whole pump. I've always just bought the rebuilding kits and have had total success with these kits. I did buy a pump for my Ford 8N because the cost was about the same as a kit for an Allis. I've even rebuilt a 1936 Oliver pump with spare parts from Rusty Acre. And I've bought several kits from Agco Allis.
Maybe the kits are the same but the castings different. But I don't think so. Call AGCO if your still nervous about it.
