water pump
shagman
12-21-2006 12:29:37
Anyone know if they sell a rebiuld kit for a model B water pump?
Paul from MI
12-22-2006 05:49:35
 Re: water pump in reply to shagman, 12-21-2006 12:29:37
Just a quick tip. Add some water pump lube to the coolant when you put either a used pump or a rebuilt one on. If I had done that my B would still have the same pump on it as when new in 1948. Also if you change anti freeze, it helps keep a dried out seal from failing.
Paul
old
12-21-2006 15:17:32
Don't know if they do or not but if you need one I have 1 or 2 of them laying around. There used but one is on an engine that was running this summer till I had a problem with a sleeve leak.
