AC C front tires
Jim Hunter
12-17-2006 12:12:25
My C currently has radial snow tires on front, Need to replace but not sure what or where to get tires. Not sure if standard ribbed tractor tires will give me enough grip in the snow and mud. Thinking I would need something with a good tread, Tractor has a front loader
1755
12-19-2006 18:41:06
 Re: AC C front tires in reply to Jim Hunter, 12-17-2006 12:12:25
Regular 3 rib tractor tiers will give you more traction in a turn on grass, gravel, and mud with less whare on your arms and your front end than truck tires but they are harder on the grass to they might cut into the sod in a tite turn
there is not much you are going to do about sliding on snow and ice unless you put steel studs in the tiers
old
12-17-2006 16:27:22
All my loader tractores have mud and snow grip type truck tires on them. I run 6 or 8 ply truck tire for all the extra weight and it also helps keep from sinking in mud etc
TxAllisMan
12-17-2006 18:34:42
 Re: AC C front tires in reply to old, 12-17-2006 16:27:22
Not sure what type of frontend your c has but mine is a tri cycle and i use the standard tractor rib tire and have never had any problems.
At one time I used donut passenger tires due to economic issues and they worked out fine. I used the multi bolt pattern passenger wheels.
