What D-15 backhoe hydraulic oil
VOV
12-16-2006 12:28:22
I recently picked up a D-15 backhoe. It runs fine and I just changed the hydraulic oil. Since the oil change I seem to have many leaks that weren't evident or nearly as bad before. I am not sure what I took out, but I put in universal hydraulic/transmission fluid like I use in my other tractors. Should I be using something heavier like straight 20W? It needs about a gallon or more now - can I add it to what is in there or should I drain again? I also never found a hydraulic filter on the system - is there one? Thanks!!
