Source for AC B Bench Seat
Ohiohills
12-15-2006 18:29:02
I"ve got a 1948 B that has no seat. The bench seat frame is there but it makes for a bad ride to have the old buns bouncing on cold steel!! Has anyone found a good source for a reproduction seat that is built like the original or, at least, looks like the original? I"ve seen a few advertised that look like black vinyl over a foam pad - probably functional but not too "original".
I"ve also read, based on other posts on this board, that the original seats were coil springs, covered with a "horsehair type" padding and then upholstered in green canvas. Can anyone confirm that? Thanks!
Stonewall
12-23-2006 10:34:46
 Re: Source for AC B Bench Seat in reply to Ohiohills, 12-15-2006 18:29:02
This is tyhe first time for me trying to respond to a question on descussion board, maybe I'll get it o.k. I have 49 B, with what I think is original seat. Description of seat is: 15" wide x 28" long x 4 3/4"-5" high. 1/2" plywood base with two 7/8" vent holes, each 7" from end and in center width wise. It has springs like used to be in 40-50's chairs & sofas, covered with something like horse hair or something shredded up, than covered lite olive green canvas. hope this helps. This ac-B has been shed & garage kept the most of it's time.
Ohiohills
12-24-2006 07:09:17
 Re: Source for AC B Bench Seat in reply to Stonewall, 12-23-2006 10:34:46
Thanks, Stonewall!! The description that you have provided is excellent information! I"m pretty well convinced that I will try and get a seat made that matches the original spring seat design with the green canvas cover. Thanks, again1
Ohiohills
12-17-2006 07:41:18
So regarding this seat question - does anyone know the height of the bench seat cushion? Seems to me that it was about 6in or so, but I can't remember for sure since it was pretty well worn out when I last used the tractor as a kid.
Ken in Tx
12-17-2006 05:50:53
Old Must not be old enough to remember what a original early B/C seat looked like or how it was made. I have seen lots of restored early Bs and Cs and have yet to see one with what I remember as a original looking seat covering which was OD canvas. They may have come new with Black vinyl seats late in production. Can"t say for shur when because our old B was still working fine till Dad quit farming in 1972. I also remember when Grandma reupolstered the seat with with a new piece of heavy army surplus canvas just like original. Cooler in the summer and warmer in the winter
Craig in WV
12-17-2006 05:46:20
If you guys have the old spring seat laying around, we can rebuild them or we can make new ones up (with springs) for you and no, they won't be lumpy. We can put the green canvas(or any color you want)on them too. So either way, with foam or springs, we can do them for you. Craig
Ohiohills
12-17-2006 07:38:16
 Re: Source for AC B Bench Seat in reply to Craig in WV, 12-17-2006 05:46:20
Thanks, Craig. I"ll try to round up some dimensions and think about what I want. I"m sure that you could make a good new spring seat without lumps! I only referneced the lumps since that is the way I remember it as a kid - but the tractor and seat were already 20 years old by then and that seat had absorbed a lot of bumps!! Sure wish the old set of springs hadn"t gotten tossed.
Craig in WV
12-17-2006 09:42:20
 Re: Source for AC B Bench Seat in reply to Ohiohills, 12-17-2006 07:38:16
The new foam ones are around 4", however was this the factory height? And does anyone remember how many springs were in these seats? I haven't laid out a platform yet to see, but it would probably hold 6-8.
Thanks,
Craig
Craig in WV
12-15-2006 22:13:03
We can make them. We can also get the canvas for them. We would use plywood, foam (your coice of thickness) and canvas or vinyl (whatever color you want) if you like. We just need the dimensions of the seat.
Regards,
Craig
Weslyn
12-15-2006 19:25:49
I made mine out fo a old couch cushion a piece of plywood and naugahide from hoby loby.
Paul from MI
12-15-2006 19:22:14
Original seat was a plywood base with springs covered by something like horsehair. Outside was a dark green canvas. That's what was on Dad's B new in 1948. Orignial seat came out second best in a yellow jacket battle in 1976 and is now covered in Naugahyde.
Paul
Ohiohills
12-16-2006 08:55:57
 Re: Source for AC B Bench Seat in reply to Paul from MI, 12-15-2006 19:22:14
Paul, Thanks for the confirmation. This '48 B has sat in a decent shed for many years without running. My Dad would use the crank to turn the engine periodically, but it hasn't been run for a long time. The sad thing about this seat is that I recall seeing the plywood base and the coil spring assembly - less the horsehair and upholstery - sitting in another shed for much of that time. That other shed got cleaned out a few years ago and I think the springs got the heave-ho. Bummer.
Sid
12-15-2006 19:18:55
Used to have a B, and knew of several of them, years ago and the seats where pretty much like you describe.
Ohiohills
12-16-2006 09:00:34
 Re: Source for AC B Bench Seat in reply to Sid, 12-15-2006 19:18:55
Thanks, Sid. I'm indecisive regarding how to replace the seat. On one hand, I'd like to have something that looks like the original seat, but on another hand, I've seen the vinyl seats - usually in black - and they look pretty sharp in contrast to the tractor's Persian orange color. I'm also not sure how happy I'd be with a foam seat rather than a good old lumpy coil spring seat!
old
12-15-2006 19:09:44
All the seat was when new was a foam rubber pad with a cover over it. Most where black and had a plywood base on them. They did make an after market seat for them that was mounted with a spring and shock set up. And yes the seat they had on them made for a ruff ride. I have 2 Cs which have the same type of seat and they can be a bear on ruff ground
allisbob
12-16-2006 16:40:20
 Re: Source for AC B Bench Seat in reply to old, 12-15-2006 19:09:44
old, original were as described. plywood base coil springs padding, possibly horsehair, and green canvas. never foam or vinyl. bob
TxAllisMan
12-17-2006 03:54:55
 Re: Source for AC B Bench Seat in reply to allisbob, 12-16-2006 16:40:20
Seats were never made out just foam and plywood as everyone has already stated. My seat is just plywood and foam covered in black vinal. Its not original but it works. Would like to find a springer seat like old described.
Just my two cents
