ALLIS RUNN'IN ON ONE
gary case
12-14-2006 10:46:57
Well i sprayed the cap (upper and lower) with starting fluid. didn't see any cracks. also sprayed inside of mag points and plate and stuff. looked good and clean. i fired her up and she sounded a little better but still running on # 4 only. i pulled all the plug wires one at a time , while it was running and nothing until # 4 and that spark could lite a camp fire. i'd hate to grab that. still no parts,Xmas time, mails slow.
gary case
12-15-2006 06:06:06
 Re: ALLIS RUNN'IN ON ONE in reply to gary case, 12-14-2006 10:46:57
MORNING, I switched the wires around nothing happens, except for#4. which has a great spark. i've got parts coming but, it's taking along time to get here. thanx for the help. old and iborange gary
IBorange in TX
12-14-2006 18:35:13
Have you checked to see if the other wires are carrying a spark??If not, then take off the #1 wire and put it in the #4 hole and check for spark. Also check for the contact points inside the outer part of the dist cap. I would start by checking the other wires and see if they carry current.
Good Luck..... ...
old
12-14-2006 15:46:43
Are you saying you don't have spark on any of them other then #4?? If thats true then it has to be either the cap or rotor of bad bushings in the mag and the points are only working when it gets to #4
