D17 Hydraulics?
Kent
09-13-1999 08:54:03
I have a 1962 D17 with a single rear hydraulic outlet. I want to be be able to operate a two way cylinder for my top link. What needs to be done?
Thanks for the advice.
ROBERT
09-15-1999 17:38:42
 Re: D17 Hydraulics? in reply to Kent, 09-13-1999 08:54:03
there is a pipe plug on the lift side of tran under fuel tank clos to the place were the pis. line comes out. run a hose from there to back were the other cuppler is.place the return hose of cyl.(no load side of cyl.) in new cuppler. if you need psi on both sides of cyl. you will
need to install a open center valve.psi coming
from old cuppler ,return to new cuppler,and cyl.
plugs in to work ports of valve.and move pump contol lever to pump on spot. hop this will help ROBERT
Kent
09-16-1999 09:25:06
 Re: Re: D17 Hydraulics? in reply to ROBERT, 09-15-1999 17:38:42
Thanks, that sounds like what I needed to know.
