190xt slips out of gear
RossinKY
12-10-2006 17:27:36
My 190xt slips out of high gear when I slow down or go down hill.What parts need replaced and will it be an easy fix.
Joe(TX)
12-11-2006 06:13:23
 Re: 190xt slips out of gear in reply to RossinKY, 12-10-2006 17:27:36
The parts that normally need replacing are the input shaft and the coupling. On the early ones you could get the input shaft out from the front, but not on the later ones. You may want to make sure the shifter fork is not bad before you tear down the tractor.
Brad Wright of MO
12-10-2006 18:12:22
No actually thats a pretty tough repair. You would have to split the tractor. I would just take it to a shop it would be a lot easier. It'll prolly be a little pricy but its well worth spendin. In the future make sure you dont grind the gears thats what causes this. Always push the clutch fully down and if you need to slow the throttle down that wikll make it slow quicker. Just remember its not a powershift transmission, be patient.
BigMarv1085
12-11-2006 04:51:01
 Re: 190xt slips out of gear in reply to Brad Wright of MO, 12-10-2006 18:12:22
That happens to all of the 190's, it is very expensive and sometimes they start jumping out of gear shortly after.
