wd-45
wegman in Mn
12-09-2006 08:46:02
as far as I'm concerned I am allis dumb. Did allis chalmers make the wd-45 as unstyled? If not could someone in the right mind could put wc unstyled sheet metal, radiator, and gas tank on one?
Jerry Coulter
12-09-2006 10:21:20
 Re: wd-45 in reply to wegman in Mn, 12-09-2006 08:46:02
If you could get the gas tank support from an unstyled WC to fit on, then the rest should go on OK. It would be a unique unit.
Dave Wi
12-09-2006 09:01:54
I spose with a little fabricating yeah it'd fit,or you can put a WD45 motor in a WC. Answer to first part NO,all unstyled were WC's from 1934-1938, WD45's came a little later 1953.
