allis chalmer B
info needed
12-07-2006 19:03:12
fixin to overhaul a allis.There is no seriel number on the block,can someone tell what kind of engine was put in them..i know it is a four cylinder.but i would like to know before i get into it.If anyone can help me i would really appreciate it..thank you
gary case
12-09-2006 12:49:22
 Re: allis chalmer B in reply to info needed, 12-07-2006 19:03:12
speaking of the devil. that's what i'm trying to find out. i have a 1949 ( Late) B. I put a C 125 ex manifold on it and it leaks. didin't on the C. ARE THEY the SAME MANIFOLDS? the serial # CR 359997.is on the back of the blk by the bell hsing. the dealer that was in a hurry to close today told me he didn't have those #'s. He had 113 123 130 or 135. He wanted to go home i think. anyways, thanx Gary ps tr # B 92323
D13
12-10-2006 03:24:45
 Re: allis chalmer B in reply to gary case, 12-09-2006 12:49:22
CRXXXX is a combine engine, it's a 125CID CE engine with 200 more RPM and an oil tray on the valve studs. It's not unusual to find them in B's and C's. Manifold should work fine. Find our whre it is leaking then chek both surfaces and the gasket. IF the previous manifold leaked perhaps the head mounting surface is not flat.
Andrew Z
12-09-2006 16:37:50
They should have all the same manifold. as for the numbers he gave you for the engines those sound like IH engines numbers not Allis.
Andrew
Andrew Z
12-08-2006 07:09:03
the number should be on the left hand side of the block (by the bell housing) if it is a CE motor the 125cid. If it is the 116cid then it is on the back of the block (between the motor and the gas tank) I have one of both a 1938 that has the 116 in it and a 1948 that has the 125 in it.
Andrew
old
12-07-2006 21:06:40
From what I understand there where 2 engines used it them. One was smaller then the other and was used in the early ones. The most common one is the B125 engine which was used in the B,C,RC, and the CA.
bjb in Ne
12-07-2006 19:22:25
Are you sure theres no serial number on the engine or do you need to know where to look?
allis wd
12-07-2006 19:18:48
it is a allis chalmers made engine. you can get every thing you need at your friendly parts place or dealer.
