WC differential clunking
RKEENE
12-06-2006 12:39:57
My 1939 WC has developed a catastrophic clunk emanating from the rear end. These are the symptoms:
Not a growl, but a tumbling clunk
Occurs with tranny in neutral,when rolled, or any gear
Occurs when either rear wheel is jacked up and hand turned
I'm pretty convinced its a differential problem.
Is a complete, used rear axle in order, or should I tear it down and rebuild? Any suggestions or diagnosis are appreciated.
RKEENE
12-19-2006 06:58:12
 Re: WC differential clunking in reply to RKEENE, 12-06-2006 12:39:57
Inspected through the back cover as suggested, and found the carrier casting to be broken on one side. I've located a used differential and will install it over Christmas break. Thanks for your input.
JMS/MN
12-06-2006 15:11:23
If it's a WC, it should have a pop-out cover in the center rear. Pry it out with a screwdriver and visually check the insides as best you can before doing a frontal disassembly. Should be able to check gear condition, might find a bad bearing making the clunk.
David Maddux
12-06-2006 14:44:17
Before you tear it down, make sure that your rim is tight to the hub. It sounds like a rim shifting on the hub.
Texas Denny
12-06-2006 13:04:33
I know it is a lot of work but i'd disassemble ehough to pull the cover off and see what is up. Until you know the exact issue, you won't know whether a couple of parts will fix or you need a whole rear axle.
