What model is this?
Jrry
12-05-2006 13:07:42
third party image
I'm not famalier with this tractor. I'll try and post a picture. thanks
kelly hull
12-24-2006 20:23:04
 Re: What model is this? in reply to Jrry, 12-05-2006 13:07:42
I have owned several B allis, and that looks to be a standard B with the optional adjustable front end that someone has put a D-10 or D-12 engine, hood, and grille on. The potato special, and the assparagus special tractors were high clearance models equipped with 38" rear tires and extended front spindles. A small D series engine will bolt on to the B transmission but the block will have about 1/4" higher flange on the sides. Hope this info has helped. The Allis-Chalmers story is a very informative book if you can find it, it may be helpful in future identifications.
Herb Brady
12-10-2006 11:59:18
Steering isnt correct for a B looks more like a wide frnt off a C, because it has a gear box in frnt and a B doesnt Herb
David Maddux
12-06-2006 14:47:57
Could this be one of those rare "Heinz" tractors?
Dave Wi
12-09-2006 09:16:48
 Re: What model is this? in reply to David Maddux , 12-06-2006 14:47:57
yep,I agree lots a different parts BUT they all look like Allis parts.
Jrry
12-05-2006 19:24:32
This is not my tractor but I saw it and it looked like a D series front and a B seat and transmission. Wheels looked like a D series also. Maybe it is a hybrid. thanks
Eldon (WA)
12-06-2006 08:00:15
 Re: What model is this? in reply to Jrry, 12-05-2006 19:24:32
Those look like cast iron hubs on the rear....all spin-out hubs are pressed steel and have a flat face.
JMS/MN
12-06-2006 20:54:50
 Re: What model is this? in reply to Eldon (WA), 12-06-2006 08:00:15
I agree- and I can't see any rails for the spinout wheels. The front is definitely D styling- looks like a morphodite to me.
steve(ill)
12-05-2006 18:34:15
those are standard 24 inch rear rims and looks like they have spin outs--- might be rear wheels are off a D10 or 12, just like the motor and hood.
steve(ill)
12-05-2006 16:00:22
look a little closer guys, the back end is a B or C tank, transmission, fenders, and seat. the hood and radiator are from a small D series????? ?? what is it, i am not sure. Looks like a mix. What engine is in it. Look on the left side of motor rear edge aginst the fly wheel housing. Might have a serial number and a motor number there???
chalmersbob
12-06-2006 17:22:03
 Re: What model is this? in reply to steve(ill), 12-05-2006 16:00:22
steve, i think your on the right track. i over looked the d style front end. also looks a little different at the tool box. bob
CHALMERSBOB
12-05-2006 15:40:34
THAT IS A STANDARD B WITH THE ADJUSTABLE FRONT AND REAR. I HAVE ONE LIKE IT. A LOT AROUND.
ASPARAGUS SPECIALS HAD LARGER REAR WHEELS AND HIGH FRONT SPINDLES TO CLEAR THE TALL PLANTS.
BOB
Texas Denny
12-05-2006 16:02:04
 Re: What model is this? in reply to CHALMERSBOB, 12-05-2006 15:40:34
A correction is in order from me. This one is called the Potato Special. As you say, the Asperagus Special does have the high arch and larger tires.
Texas Denny
12-05-2006 14:38:41
It is a B but it is an Asperagus Special B with an adjustable front axel. Don't know how many were made but I would guess very few.
