Hi Damon, Yup, that's a Char-Lynn torque generator. You might be able to install one in the steering column between the steering wheel and the gear box. It would not be a simple installation though since you'd have to cut away and support the outer column to install the generator in the shaft itself. Possibly it could be placed immediately below the steering wheel and before the column support. That would make it easier. You'd also need some kind of live hydraulic power, either from a crank-mounted pump or from a automotive power steering pump driven with a belt off a twin front pulley - or piggy-backed off a modified generator/alternator drive. Or possibly some other arrangement. Even if you kept the PTO running by dedicating it to the power steering, the standard AC-C pump would not provide the 3 gpm needed for the torque generator. Plus the pressure is way too high. I suppose if you do not use the PTO for any other use, you could install one of the PTO shaft pumps that are available. Of course you'd need a reservoir and all the fixings to go with it, as you would for a crank-mounted pump. I installed power steering on my Oliver 77 using a torque generator. That was fairly easy since I already had plenty of live hydraulic flow available and could steal some (3 gpm) using a priority valve. You can see my installation here. You might also want to investigate doing something strictly mechanically, rather than hydraulically, to decrease the turning effort. That make the take the form of some kind of gear reduction arrangement between the steering wheel and gear box. Just thinking here. I don't have anything specifc in mind. It would need to be an in-line reduction however and not a right angle unit. Also not a high reduction ratio. I would think no more than 2:1. A larger diameter steering wheel (or "outriggers" on the existing one) might also be something to consider. Rod
