WD45 starter bendix
JackT
12-04-2006 08:34:59
The bendix spring broke on my WD45 and the drive teeth are pretty chewed up anyway so I need to replace the entire starter drive. I've found a number of different replacements on line but they all require the part number of the starter for exact identification. The original tag on my starter is gone. Its a rebuilt unit and the tag is from the rebuilder, Unit Parts Co. and the number is 10 66 ST 7951 which doesn't correlate to any AC numbers. Does anyone have any ideas for ordering the correct bendix replacement, short of replacing the entire starter?
Jerry Coulter
12-05-2006 17:32:03
 Re: WD45 starter bendix in reply to JackT, 12-04-2006 08:34:59
I used to sell the same drive to fit all WC's and WD's having Delco Remy starters
BCnT
12-04-2006 15:34:37
the number is stamped on field housing...you may have to do some digging but its there
Bob
12-04-2006 09:17:29
My tractor has a Delco 1107951 starter. Some research shows they used a 1107017 Delco, too.
I APPEARS the same drive fits EITHER starter.
There MAY be different drives available... the old type with a big spring, and a more modern version. I'll look into it a little more, if I get time this afternoon.
