d 15 noise in tranny/final drive
david siders
12-03-2006 12:22:52
my d 15 has a banging noise in the forward gears it gets worse if the tractor is pulling something but is quiet in reverse almost acts like it binds up at times does anyone have any suggestions what it might be
ihcjdall
12-09-2006 07:26:25
 Re: d 15 noise in tranny/final drive in reply to david siders, 12-03-2006 12:22:52
have the same problem with my d19. after removing the cover i found out it had a bad pinion bearing and a couple teeth broke off the pinion gear. i have found several used sets for 300 to $400. atis salvage yard list or www.adeptr.com/agyards is a good place to start.
Dale(MS)
12-09-2006 06:56:34
David, Hope its something simple. Might chech and see if the spin out rims are locked down good to the rims. If loose they can make a popping or a banging type sound. If no luck there I might try getting the rear tires off the ground and look for slop in the final drive area.Then might pull the shifter plate and take a look or the pto housing and see whats going on. Dale
