Old: Thanks again
farmerwannabe
12-03-2006 09:47:26
Thanks for the suggestion about the the gas tank freeze-up. As always, it worked like a charm and I plowed the driveway happy as ever. Had the empty the sediment bowel a couple of times at first as the water settled out, but after that it ran great.
Thanks!!!
old
12-03-2006 14:08:06
 Re: Old: Thanks again in reply to farmerwannabe, 12-03-2006 09:47:26
I forgot to say this also. If you have lots of water in the tank just use more heet since it removes the water and makes it so it will sort of burn. Some thing happen to you if you get to drunk the next morning your head hurts because it removes to much water from your body. All heet is is alcohol any how and it absorbs the water
old
12-03-2006 10:59:33
Sounds like you need to buy your gas at a diifaernat place if it has that much water in it. I know years ago I got some gas from a place and got the tractors ready for the comeing snow and when I went to start the tractors every one of them had froozen up sediment bowls. I did the heet trick whcih did work but I have NEVER got gas from that place since
