No quick way to stuff the balls back in. Need to pull the auger and tube take the plug out and put the balls back then weld back up. New balls are available from Agco. I think steve missed things a little. There is no way to easily rotate the bearing unless you cut off a stud and weld on a new one where there is none. You could also put on a new pivot. I am putting one on my machine with the nylon bearing. Cost about $430 with shipping from Sloan Express. I' try a link. Don't worry quite so much about the SN break. I am putting one ot these on SN 22861 which is 2000 earlier than they say it will fit Just need to put on a longer chain. Only thing is I am replacing one with the nylon bearing do to failure. New one from Agco is $1300. Another good idea that I have always done with those augers is to put in a cleanout door for the gap in the pivot. If you haven't when you take this apart you will find some real nasty stuff in there. I just drilled or cut a 1 inch or bigger hole and bolted on a 3/8 X 2 plate to cover. If you are about done hook up a couple of cables to the tank and leave the auger out. Just be careful about doors and poles. jt
