D17 Series IV Loader Hydraulics Quit
ssgnai
11-28-2006 19:45:52
My AC has been neglected while I've used a Bobcat (go ahead and scold me), and I'm not an expert at all, but now I need to get it back and working. I have the following hydraulic issues.
1. Both rear ram seals leak a bit.
2. The rear valve manifold has one small drip.
3. I'm not sure I have the proper fluid levels.
These issues all existed before and my Ford loader worked fine. Now its dead. I changed the filter to no affect. I "think" the fluid levels are correct. The rear rams/arms move, albeit slowly. I was thinking I should take the pump off and down to the shop to be rebuilt, but am not sure that is my issue.
Can someone walk me through the idiot steps? I would be very grateful.
Thanks.
Steve
ssgnai
12-03-2006 06:30:08
 Re: D17 Series IV Loader Hydraulics Quit in reply to ssgnai, 11-28-2006 19:45:52
Looks like my reply from last night got into the thread out of order - don't know how. One question in addition to those. You mention checking the quick connects. What should I look for besides rust?
In thinking about it I've also become convinced that I'm not getting pressure out of the rear aux connections via their hoses up to the loader valve manifold. I have both control handles between the seat and fender to the rear position, which I think is how they are supposed to be.
Your pictures were VERY helpful. Thank you.
Gatz
11-28-2006 20:22:31
Steve,
I wouldn't rush into taking the pump off just yet.
Some of those symptoms sound similar to what some others have experienced; especially the hydraulics not working after sitting idle for a while.
In fact, a local guy that has a D17SerIV had this very same problem (his tractor has a Do-All loader)
One recurring theme is that the Traction Booster valve or linkages are causing this condition.
A side effect of the valve hanging up is constant whine from the relief valve (on the valve stack) & increased oil temperature.
Look underneath the flat plate where the valves are mounted. The TB valve is the spring-loaded return plunger type and can hang up. Kinda hard to get at, but try spraying some WD-40 or the like on the stem, and work it back and forth with a rod or wooden dowel.
Another source of trouble is the linkages/bellcranks underneath that come from the lift arm on the right side. Sometimes the bellcrank can rust tight to the stud that it's supposed to pivot on. There's also some linkages in front of the rear axle housing that should be looked at to make sure they move freely.
Hope this helps
Here's a picture from under the plate.
third party image
Here's one from the rear...
The "bellcrank" is right ahead and to the right of the downward loop in the return line.
third party image
ssgnai
12-02-2006 20:51:19
 Re: D17 Series IV Loader Hydraulics Quit in reply to Gatz, 11-28-2006 20:22:31
Update. The bellcrank was not putting pressure on the valve no matter the handle position because the bell crank pivot closest to the valve was frozen. I found this out by taking the fender off and removing the top plate from the valve, connecting rod, bell crank assembly area and finding that it didn't move. Lubed it all up and loosened the bolt slightly and reassembled. Valve now gets pressure from handles.
Here is the current status of my problem. I am making progress and thankful that you are so helpful.
The rams are now raising and lowering properly. However, the tractor has a Ford loader on the front fed by the the left rear aux outlets. It is not functional. The left valve control piston under the seat appears to work fine, but I don't get any action on the arms and bucket from the control manifold mounted up by the seat. A couple of things occur to me. Is the pump very sensitive to fluid level in case its slightly low? Could I have some blockage affecting only the aux outlets? Can a DIY'er flush the system? Also, the TB return line is dripping, but I can get a wrench on it to tighten it.
Please don't give up on me. :) Thanks!
Steve
ssgnai
12-02-2006 16:09:23
Thanks for the ideas. The friction bolts appear to be so loose the action isn"t putting any pressure on the valve. I think I can tighten them, but neither of my two manuals are clear about the setup. Any ideas?
Gatz
12-02-2006 19:07:45
 Re: D17 Series IV Loader Hydraulics Quit in reply to ssgnai, 12-02-2006 16:09:23
When you say the action isn't putting any pressure on the TB..... do you mean it doesn't come into contact with the stem ?
IF so, the TB valve is probably stuck and needs to be freed up so that it bears against the cam-shaped pivot. This is probably the hardest thing to see and get at, but it's important.
This was the problem the local guy had with his.
I think you can safely remove the rear cap that's held on by 2 socket head screws (2nd pic view from rear) and be able to push the stem forward. Go back underneath (1st pic view) and push it to the rear. Repeat a lot of times making sure it's free. Do this while the tractor is shut off. Then if and when it frees up, you can try the valves with it running.
And as was suggested, make sure your quick-disconnects are OK.
