WD 45 diesel/gas trans/rear end
Collin45
11-26-2006 13:44:48
Will a wd45 gas transmission and rear end bolt up to a wd 45 diesel. How much faster is the gas rear-end. Has anyone out there ever don this.
m. tremblay
11-26-2006 18:13:06
 Re: WD 45 diesel/gas trans/rear end in reply to Collin45, 11-26-2006 13:44:48
the pinion and ring gear are different. wd45 part number 225972 and wd45 diesel pn 237111 (same as d17 serie 1) and pn for pinion is 225937 for wd45 and 227221 for wd45d
wdTom
11-26-2006 17:12:37
My parts book says they have the same part no. for the ring and pinion, and the same for the final drive pinion and bull gear. I don't think there was any difference in first,second, and third either, fourth would be 1 to 1 anyway.
wdTom
11-27-2006 18:30:11
 Re: WD 45 diesel/gas trans/rear end in reply to wdTom, 11-26-2006 17:12:37
Please see my post below in the diesel post which I somehow got there by mistake.
Texas Denny
11-26-2006 16:56:59
This is a great question. I have some info. According to my references, the ground speed at rated RPM in each gear is the same for all models of the WD-45. Since the diesel rated RPM is 1625 versus 1400 for the gas model, it would seem to indicate that the rear axel ratio between gas and diesel is different. If this is true, the gasoline rear end on a diesel would go 16% (1625/1400). Hopefully someone of our readers will have the actual ratios.
