39-B
joyride
11-25-2006 08:12:24
rebuilt engine, crank turn fine but when i torque the rods i cant turn it, i had a shop mic the jurnals they said everything was standerd. is there a shim kit, or are my bearings wrong?
thank-you.
joyride
12-01-2006 18:02:27
 Re: 39-B in reply to joyride, 11-25-2006 08:12:24
THANKS,to everybody that helped.
wdTom
11-26-2006 17:23:13
There is more to shimming than just sticking them in. You need to maintain proper bearing "cruch", and clearance. Look back in archives, or get a good manual, I&T is OK, reprint of AC better, both best.
Dennis in Wisconsin
11-25-2006 15:41:42
I also have a 39 B and the engine was tight when I bought it. I took it apart and put it back together with all the old parts and remember that there was 4 shims on one rod. amount of shims will very. works and runs like a top. good luck
joyride
11-25-2006 10:08:14
THANK-YOU.
Dick L
11-25-2006 08:20:24
 Yes Sir On The Shim Kit in reply to joyride, 11-25-2006 08:12:24
You will need a stick or green plastigage and shims which can be had from an auto parts store like NAPA. You can buy them or cut them from shim stock. A bunch easier with the boughten shim kit for those types of engines.
Patches
11-26-2006 18:35:36
 Re: Yes Sir On The Shim Kit in reply to Dick L, 11-25-2006 08:20:24
Dick, You were kind enough to answer my question on Allis motors back on page 15 a while back, I have some more questions, could you please call me, or -send me a number that I could call you (417-642-5751),
Many thanks, Patches
Dick L
11-25-2006 08:23:34
 Should A Read in reply to Dick L, 11-25-2006 08:20:24
Should have read the first statment afore I posted it. Might not be able to get the shims at NAPA but that is where I get green plastigage.
