T3 Gas Dozer
Tom Windsor
11-23-2006 20:33:02
I have purchased a T3 Dozer. I am not getting power to the right track. Does anyone have experience replacing the clutches on this machine.
Tom Windsor
jhill52
11-25-2006 05:40:04
 Re: T3 Gas Dozer in reply to Tom Windsor, 11-23-2006 20:33:02
If you mean an H3 I just bought one. Clutches come out from top under fenders. Doesn't look like too bad a job. You should get a service manual though.
Jerry
GLENN PYZAK
11-27-2006 12:03:47
 Re: T3 Gas Dozer in reply to jhill52, 11-25-2006 05:40:04
The sterring clutches
are on the right and left side of the seat.There is a small inspection cover to adjust the brake
band.Also under the fender on the final drive housing,there is a large bolt
and lock nut.Loosen the lock nut and turn the bolt inward.If none of this works your in for 4-5hrs of fun.The parts are exspensive,but once
done should last for YEARS!!ive done several of
these.The bad part about removing the sterring
clutch assy is the clip,that holds the stub axel in the clutch assy,just hard to get to.
Tom Windsor
11-25-2006 14:03:13
 Re: H3 in reply to jhill52, 11-25-2006 05:40:04
Yes, I mean H3. I hit the wrong key....:-(
CH
11-25-2006 03:04:13
Do you mean H3 ?? If so i have parts for that machine. Also shop manual.
jhill52
11-25-2006 05:37:33
 Re: T3 Gas Dozer in reply to CH, 11-25-2006 03:04:13
CH, I recently bought an H3 need some parts what do you have? Email is open.
Jerry
