WD-45 Air Cleaner Elbow
Jud Fisher
11-22-2006 16:50:40
After searching a lot (but not exhaustively) , the only reasonable alternative to replacing an air cleaner-to-carb rubber elbow on an AC WD-45 seemed to be the dealer---AGCO. The part is an exact fit and well worth the money. Part Number 70-226-266 (my hyphens just to make sure the number was correct). Best of all, it wasn't made in China, but right here in the USA!!!
Kent of SW MO
11-23-2006 08:42:32
 Re: WD-45 Air Cleaner Elbow in reply to Jud Fisher, 11-22-2006 16:50:40
The last I knew AGCO-ALIIS did not use hyphens in their part numbers. Should be 70226266. I know that parts for my C-II Gleaner only need a "7" added in front of the old Allis number. The Gleaner P/N are one digit longer than the tractor P/N so I assume you add a 70 to the tractor P/N Old P/N would be 226266 which would make a 6 digit number Like was use when I worked at an Allis dealer in the late 60's and early 70's.
Kent
Sid
11-23-2006 21:33:18
 Re: WD-45 Air Cleaner Elbow in reply to Kent of SW MO, 11-23-2006 08:42:32
Kent, if you don't mind my asking, what dealer was that?
Kent of SW MO
11-24-2006 02:52:42
 Re: WD-45 Air Cleaner Elbow in reply to Sid, 11-23-2006 21:33:18
Payne Imp. Bolivar Mo.
They are still in bussiness though on a smaller bases.
Kent
Sid
11-24-2006 11:45:29
 Re: WD-45 Air Cleaner Elbow in reply to Kent of SW MO, 11-24-2006 02:52:42
Thanks for the reply. I have been there before and was impressed with the overall attitude and service. I did not know they were still in business.
