WD45 hydraulic bucket droops
OldIron
11-22-2006 09:26:06
Hello,
I have a WD45 with the gravity drop bucket.
When the standard hydraulic control is moved from the lifting direction, the left side of the bucket drops and the right side stays at the same level as selected.
What do you think is the problem?
If there a selector valve rebuild kit or adjustment or something?
I couldn't find anything in my old manual.
Any advice would be appreciated.
OldIron
old
11-22-2006 09:42:21
 Re: WD45 hydraulic bucket droops in reply to OldIron, 11-22-2006 09:26:06
Sounds like you may have a bad cylinder on that one side and its leaking past the cylinder seal.
OldIron
11-24-2006 06:41:34
 Re: WD45 hydraulic bucket droops in reply to old, 11-22-2006 09:42:21
Old:
The cylinders are single acting cylinders.
No fluid is leaking out of the rod end of them even at full extension and pressure. I have bled them, no help.
I was wondering if the control valve has perhaps failed on one side with a manual 'check-valve' or some such adjustment out of tolerance?
I can't find my old manual to verify how the hydraulics are set up. I know I have the manual, just can't seem to locate it.
Thanks
old
11-24-2006 09:06:58
 Re: WD45 hydraulic bucket droops in reply to OldIron, 11-24-2006 06:41:34
Most hyd cylinders where 2 cylinders are used there is a T in the line and because of that the valve can not cuase the problem, only a bad cylinder can cause it. Doesn't matter if its single or double acting. Had that type of problem this summer on a round baler, one cylinder wnet bad and one side would statrt to open. Now I would think your bucket would full stright
