190 tranny leaks into hydraulics
LLR
11-22-2006 09:20:10
I'm taking the engine out of my 190 and thought i would split the torque tube and fix the leak that causes the tranny fluid to go into the hydraulics. The problem is that i cant find in the IT manual where i would be leaking.Can someone point me in the right direction? I need to know what seal it is so i can order it . Thanks
Skyhighballoon(MO)
11-22-2006 10:10:43
 Re: 190 tranny leaks into hydraulics in reply to LLR, 11-22-2006 09:20:10
LLR - 190 should be similar to my 180 as they share the same basic torque tube. It's the transmission input shaft and the PTO shaft. The transmission input shaft takes one seal and the PTO shaft takes two. Probably less than $25 for all three seals. Replace them all while you are in there. Mike
