WD torque tube-from the front or from the rear
RandyN
11-21-2006 17:40:46
Hello All,
In short, I need to replace that seal in between my hydraulic reservoir and the transmission. Since I have to split the tractor, I'd like to put in a new engine clutch and rear main seal while I'm at it. However, as I study the manuals, Service and I&T, they seem to describe the process by removing the transmission from behind.
1. Can I not pull the torque tube and replace the seal by pulling the engine? (which will allow me to do the clutch and rear seal, etc.)
2. By pulling the engine, can't the tractor rest on it's own wheels throughout the process?
Thanks for the thoughts of experience.
RandyN
wdTom
11-21-2006 17:53:49
 Re: WD torque tube-from the front or from the rear in reply to RandyN, 11-21-2006 17:40:46
Yes, I think you cantake it apart that way. It is ealier the other way, supporting the frame with bolt on legs with a wide base, blocking up the torque tube on a dolly and rolling it, the transmission andrear end back. Your way you will have to take of wne frame rail, left one is easier. Pull engine, pull bellhousing, then torque tube.
RandyN
11-22-2006 05:55:34
 Re: WD torque tube-from the front or from the rear in reply to wdTom, 11-21-2006 17:53:49
Thanks for the reply, WDTom.
It'll be a lot "taking things apart", but it will allow me to install a new clutch and rear main seal while I have everything apart.
Thanks!
RandyN
JMS/MN
11-22-2006 13:37:55
 Re: WD torque tube-from the front or from the rear in reply to RandyN, 11-22-2006 05:55:34
If the only reason to split was to replace the seal between the transmission and the torque tube- splitting at the axle would make sense. But since you want to replace the clutch, it is much simpler to pull the engine, and the next two housings behind. You don't need splitting stands, don't have to worry about the front half tipping on you, and you do not need to remove a side rail. Just loosen the bolts, leave everything intact, spread the rails a bit with a pry bar, lever, jack, etc. to loosen things up, and you can slide the castings forward, leaving them between the rails. Once the engine is out you have plenty of room to work with the clutch housing and torque tube. I have one in the shop right now like that, on all four wheels. No need to complicate a simple job.
