WD45 and Round Bales???
Mike Gibson
11-20-2006 19:08:08
Hello,
We're trying to find an affordable tractor that can handle 600-800lb "small" round bales. The next one we're scheduled to go look at is a WD45 with a 3pt hitch. Using a 3pt bale spear, would a WD45 safely lift and move a small round bale from a trailer to a round bale feeder a hundred or so yards over fairly flat ground?
Anything else I need to know on these? This would be our 1st Allis!
Thanks,
Mike
bgm
06-21-2007 14:08:27
 Re: WD45 and Round Bales??? in reply to Mike Gibson, 11-20-2006 19:08:08
I move 1500lb bales with my WD, not a WD 45. It has a front end loader and I've added another 400 lbs to the front. I went through the pump and set the pressure back to the factory specs. With 3500 psi showing the bale creeps up slowly, with 3700 psi showing it comes up nicely. The WD45 has the same hydrualic setup and should perform in the same manner.
Mike Gibson
11-25-2006 08:55:27
Thanks for the advice guys. We went ahead and passed on the WD45 mainly because it wasn't quite as advertised. If anyone is looking for a WD45 with a WF in Indiana ($1750), drop me a line and I'll pass along his contact info. It'd be more of a collector's unit than a work tractor. As far as the D17's, we couldn't ever find one in our price range. Thus, we went with another Ford (a 2000) and a big Allis will continue to be a future dream. Maybe in the meantime I'll paint my B-207 orange! LOL! It IS a AC after all!
Take Care,
Mike
Bill(Wis)
11-25-2006 08:19:24
Good advice about the D17 but just for the fun of it, look around for a D19 gasser. Terrific tractor for about the price of a D17. Might be hard to find though.
85_Ranger4x4
11-21-2006 09:02:17
I would say that would be the absolute max a wd-45 would move. We get ours custom baled and at about 2/3 the size of a regular bale and it is all our wd-45 wants. We have 400 lbs of weight on the front, usually the pump gives up before the tractor gets light. This is with a snap coupler bale fork too.
John (C-IL)
11-20-2006 19:35:15
You would probably be better off with a D17 for not much more money. The WD45 will probably have a pretty limited lift height with a 3 point conversion, and if you did get it high enough you would be far enough back on the tractor that it could be pretty unstable.
