Yes You Can
Dick L
11-19-2006 09:21:20
You have to turn the crank back and forth. You can not take the pistons out the top anyway. The rods will not fit thru the holes. I like to push the piston up as high as it will go and put the rings on but I have big stiff hands. It really in not that bad getting the rings in the cylinders from the bottom. The first one may give you a fit or two but after that you will have it figured out. If you have not figured it out you might not should have started it without a little help. LOL!
It is always easier on a rotating engine stand but not necessary.
