The easiest way to do what you want is to take a 262 buda gas engine and put it in a D17 diesel. This will make 71 HP and bolt right in a diesel 17. Some old combines used these and they are fairly common. It is not too hard to find an older black grilled D17 that needs work for not a lot of $. If you want to build a a gas four banger d17 engine. You can run a 175 gas cam, carb, pistons, and governor spring and make over 60HP that way. This would look stock and be legal at most pulls. Either one of these combinations will run in the field all day and pull well. One word of caution. The D17 has a heavy front end and is very hard to get the weight to transfer to the rear wheels. We pulled one with 15.5 38 tires in 6500 and still could get the front end to float. A WC, WD, or 45 is much easier to get the weight to the back wheels. I don't know if the newer sixes will bolt in a D17 or not. I know a 180 or 185 has the bigger engine with basically a d17 series 4 rear end. The middle of the tractor is a mix from a 190 and a newer D17.
