Reassembly after a split
ScottBB
11-18-2006 20:52:32
I just replaced my clutch parts and have a reassembly question. The tractor is an AC 185.
How do you align the splines on the clutch disk to the clutch shaft as you are pulling the tractor back together? Will they self align? or do you have to turn the flywheel at some point? I tried to visually get them in generally the right orientation before I started pulling. Just a few inches to go, but I thought I should ask someone before I keep going.
Thanks.
ScottBB
11-21-2006 19:34:54
 Re: Reassembly after a split in reply to ScottBB, 11-18-2006 20:52:32
I was able to align it by turning the flywheel with a screwdriver through the hole in the bottom. Worked nicely and pulled back together now. Thanks.
85_Ranger4x4
11-21-2006 14:28:09
I have engaged the pto and turned the pto shaft by hand to align the splines when rolling a split tractor back together. It wasn't on a 185, but it should be the same idea.
Kent of SW MO
11-19-2006 14:46:41
This should be a single plate clutch. You can build a alinment shaft. Measure the minor diameter of the splines and the size of the pilot bearing. Then build a stepped shaft with those to diameters. I do this when i do a clutch but I must also state that I have a lathe to build the part. The late one I did for the wifes cousin I made from UHMW plastic.
Kent
