7000 ground speed
Rick Kr
11-18-2006 18:31:00
Does anyone know ground speeds for a 1976 7000 with 18.4-38 tires in first gear?
Might buy if everyting else checks out. But need the slow 1st gear for pulling a tree planter.
Thanks,
Rick
cadet trooper
11-20-2006 17:40:01
 Re: 7000 ground speed in reply to Rick Kr, 11-18-2006 18:31:00
Even if you had a chart which should be in the operators manual will be based on rated RPM which I think for that tractor was around 2100 to 2300 and I wouldn't think you would want to plant trees at that engine speed that would suck down some serious fuel. I'd ask the seller if you could do a test distance to see if it would work for your needs. I know I would unless he or she is afraid you might find something else wrong.
Obsession
11-19-2006 18:42:33
If it like our 7045 it may has a gear speed chart on the dash of the tractor.
Rick Kr
11-19-2006 19:29:12
 Re: 7000 ground speed in reply to Obsession, 11-19-2006 18:42:33
No luck in the cab, looked everywhere if one was around it has since faded away or been removed.
Rick
