WD45 Brakes
Lafe
11-18-2006 08:53:45
I'm trying to remove brake assemblies from my 1955 WD45. My problem is on both sides the bottom anchor pins are frozen in the housings.Is there an easy way to remove these? I have been using a pry bar inserted into the keeper grove and exerting pry pressure while applying heat around the pin on the axle housing. Neither pin has budged yet. I am already passed point of no return on left side. The brake pedal linkage rod broke off flush in brake yoke when trying to remove so brake assemblies must come out to repair.
wdTom
11-20-2006 18:32:09
 Re: WD45 Brakes in reply to Lafe, 11-18-2006 08:53:45
Go into the archives and search on this. Basically you grind off the case hardened outside of the end of the pin. drill and tap,I used 3/8-24 (fine thread) and a bolt or stud. It is possible to drill straight if you have a drill that isn't too large to allow it to get up against the axle housing. Use a sharp tap and good tapping fluid, you don't want a broken tap in the hole. A fine thread tap is stronger than a course thread, more metal left in the tap. You can try driving the pins in, even though this is backwards from what you are trying to do, it can loosen them up and make it possible to now twist them or pull them out, maybe not too. Always but always drill and tap new pins before you put them in, you or the next guy will think you were pretty smart when they need to come out another time. Drilling somewhat deep isn't going to weaken the pin where it neet strength, the pin goes through a lot of castiron before it needs to any strength, You can have a 1" deep hole at least I think.
Obsession
11-19-2006 18:57:08
We blow them off with a cutting torch when they are really bad. You have to keep cutting out parts and pieces any way you can get at them until you gets the darn things out.
Been there done that got the t-shirt.
You end end up wrecking the pins and brake shoes, but sometimes they just don't come out!
The pins you can make easy enough. Brake shoes you can find.
Good Luck!
George G
11-18-2006 14:01:21
When I did the brakes on my 45. I user 1" shop cloth, went up though the hole in bottom of housing, cleaned the pin the best I could, sprayed it with lots of penetrating oil. Hooked slide hammer to small end of pin. After breaking the end of the pin off. I ground the end of the pin flat with die grinder, drilled and taped to 5/16, Used a short piece of pipe with a big enough ID for the pin to fit into, 5/16 washers on top of the pipe. Used the bolt like a puller.Kept stacking washers til the pin was out. Have to get up in the hole once in a while with a bar to bend the shoe"s back straight,they will bind on the pin. Other than that, It"s a piece of cake.
lafe
11-19-2006 08:40:13
 Re: WD45 Brakes in reply to George G, 11-18-2006 14:01:21
Thanks, I actually saw where someone makes a puller but it's a little expensive. Sooo! I drew up my own puller and will have a freind make it in his machine shop and try it first before I try the welding to the pin method.
Texas Denny
11-18-2006 12:57:20
My plan is a bit unconventional but it works for me. I remove the rear wheel. Loosen all of the bolts (but don't remove the nuts - 1/4 space is good) that hold the rear axel onto the diferential. Work the axel until you can get it about an 1/8" to 1.4". It helps to support the axel with a engine hoist or the like. The motion of the axel forces the pin to loosen up either on the inside or the outside. If it loosens on the outside, tighten up the bolts and and place a good vice grip on the pin and loosen everything as you did the first time.
Drilling in these pins is not easy unless you have carbide drills.
JMS/MN
11-18-2006 09:27:27
Common problem with the WD. I drill a 3/4 inch hole in strap iron, weld it to the pin. Makes a handle to wiggle it back and forth, heat of welding helps loosen. Also apply candle wax as it cools- sneaks into the joint. Grind off the weld and reuse the pin. Install with "Never-Seize'.
