AC Model M crawler
Paul Hohman
11-16-2006 19:41:09
Looking for information on connecting rods to Crank. Not sure if it is early, pre S/N 6663 or late, 6663 and higher. Have a bumping #4 rod I want to tighten up. Are they inserted or poured bearings? Thought I should find out before I open it up. Any suggestions? Also, Where is the tractor s/n located. No manuals available here.
Paul Hohman, Paso Robles, California
Tony Carbaugh
11-16-2006 22:59:11
 Re: AC Model M crawler in reply to Paul Hohman, 11-16-2006 19:41:09
AC M had poured babbit engine unless some one spent a lot of money changing it over to inserts. Serial # top of trans on right side. Tony
Paul Hohman
11-17-2006 07:54:18
 Re: AC Model M crawler in reply to Tony Carbaugh, 11-16-2006 22:59:11
Thanks for the information. Will get into it soon. Friend has the crawler and wants to use it but the knock is the problem. Do you have any idea what the bearing is to be set to? 0.001-.0015? Hope there some shims in there to remove like in my Model A Ford, 1929 Tudor.
Thanks again
Paul Hohman
