Aux hydraulic pump on a WD45
JackT
11-16-2006 10:21:22
Today in a junkyard I saw a WD45 with an auxilliary hydraulic pump (for a loader) mounted behind the distributor, getting its power from the distrubutor drive. Would this have been store-bought or a home-brew modification? Who ever did it did a really good job. Wouldn't that put quite a load on the distributor drive shaft? I can't imagine those gears were designed for that kind of load.
Unfortunately the dealer wouldn't sell just the parts-would have had to buy the whole tractor--an incomplete, nonrunning junker for $1500!!
JMS/MN
11-17-2006 08:22:18
 Re: Aux hydraulic pump on a WD45 in reply to JackT, 11-16-2006 10:21:22
Might have been a CharLynn unit. You can add a pump in front of the crankshaft pulley to get additional hydraulics.
John Schneider
11-17-2006 07:19:10
Yes...you're right about it being a hydraulic pump, but it is the hydraulic pump for the power steering unit that Mike was talking about.
Mike in Ohio
11-16-2006 18:48:56
Jack I'm not positive but that may have a power steering unit rather than a hydraulic pump. Mike
IA Roy
11-17-2006 20:00:04
 Re: Aux hydraulic pump on a WD45 in reply to Mike in Ohio, 11-16-2006 18:48:56
We had a Farmall M with a distributor drive hydraulic pump that ran the loader I know that some AC's and some Farmalls used the same Delco Remy distributor. It stands to reason if the pump would work on one, it would work on the other.
