WD-45 Air Cleaner
Phill Snartland
11-16-2006 07:30:45
Hi All,
I've got a nagging problem on my WD-45. The oil bath air cleaner weeps oil out onto the clutch housing. I've been careful to keep the oil level at the right height and to use 30w oil like the book says. I'm afraid that if I drop the oil level to stop the weeping, the air cleaner won't be effective and I'll get dust and dirt into the engine. It's annoying because this is a tractor that I show as well as use.
Has anyone had experience with stopping a leak like this? Has anyone found a conversion that would fit a paper or foam element to the original canister, so the look would be maintained?
Thanks for all your help!
Phill
Kent of SW MO
11-17-2006 06:52:24
 Re: WD-45 Air Cleaner in reply to Phill Snartland, 11-16-2006 07:30:45
Does the leak move depending on how the oil cup is installed or is it always in the same place. If the leak move with the oil cup clean the cup and check for acrack in the cup. If the leak does not move remove the whole air cleaner and look for a crack in it. OR find a total replacment from a salvaged tractor.
Kent
