WD ???
INWoody
11-15-2006 09:27:57
A fellow I work with has an old Allis that I believe is a WD, even though he was sure it was a WD45. I found the serial number on the diff brake housing: WD73170, which would identify it as a 1951 WD as I understand it.
I know my way around the old Fords, but haven't been around the Allis tractors much at all. I've been looking around this site for any info I can gather, and I'm wondering if someone could direct me to some other sources of info on these ol' girls as well.
This particular tractor is equipped with a magneto ignition and a belt drive on the RH side, and I'm curious if this was pretty much standard or if there is any rarity to it at all. The overall condition of the thing seems to be pretty good, and he's wanting to get it fixed up and painted and get some occasional use out of it.
Any input is appreciated!!
JMS/MN
11-15-2006 10:41:36
 Re: WD ??? in reply to INWoody, 11-15-2006 09:27:57
Serial number tells it all. Engine updates and changes could give the same power as a WD45, but the serial number is on the differential, so transmission is a WD. WD came with magneto ignition, some were changed later, standard on WD45 was distributor. Pulley was available on both models. About a quarter million made, so nothing is rare.
old
11-15-2006 10:19:05
Sounds like the run of the mill WD tractor to me. Now it could have a WD45 engine in it since they will bolt right in. The way to figure out which engine it has is look on the right side of the engine. If it has a big bolt on plate on the right side then the engine s a WC/WD engine, same engine in either one. Now if it doesn't have that plate then its a WD45 engine sitting in a WD tractor. The mag is common for those tractors but so is a distubutor type system
