a.c. model b information
bud wite
11-14-2006 18:38:49
i have a model b that has diff. sheet metal and a brass ser. tag number 65what is this thanks bud
CHALMERSBOB
11-16-2006 18:45:33
 Re: a.c. model b information in reply to bud wite, 11-14-2006 18:38:49
37 B WILL HAVE THE CARB ON THE RIGHT AND THE MAG ON THE LEFT. JUST OPPOSITE OF THE LATE PRODUCTION B. BOB
85_Ranger4x4
11-16-2006 07:46:02
I read somewhere the military used B's with cast valve covers and oil pans, might also explain the different grille and rims. The tag may also be the military serial #. Anyway to post pics? This thing sounds interesting.
AC guy
11-15-2006 20:23:44
You have the 65th AC B built. It should have a Waukesha engine instead of an Allis engine. It is a 1937. There were only 96 made in 1937. Your rear fenders are probably flat and look homemade. If it has the original engine, you got a great deal, very rare tractor. Congratulations!
bud wite
11-15-2006 19:57:47
this is a factory tag there is no numbers for gear selection that all b models have grill has a brass rod fasten agaist hood instead of preesed into the metal, tool box over torque tub is rounded with tube, cast iron valve cover,front wheels andspindels different,rear rims have a ring like a old truck all orieinal,x owner said bought in 1937 b models did not start till 1939 by books, maybe a proto type thanks bud
steve(ill)
11-14-2006 19:12:19
brass tags are normally installed by the owner to designate equipment numbers and they are not AC serial numbers.--- what different sheetmetal do you have.
