Allis B Timing.
John D Stiles
11-14-2006 16:33:25
I finally found a Fairbanks/Morse magneto for my restoration tractor[AllisB] I put the flywheel on the "FIRE" mark, and the mag in the governor housing with the rotor pointing at #1....it started and ran well enought to drive around the barn, and back to the front and died. I figured it was still a little outta time, like a gear tooth or?? Anyway it just got worse the more I messed with it, so I took it out and started over in the same sequence I did before, but NOOOOO....it backfires through the exhaust no matter where I try to put it?? Anyone that can give me some methodology fop timing my tractor will be greatly appreciated! Thanks for listening~John
Rod (NH)
11-14-2006 16:42:04
 Re: Allis B Timing. in reply to John D Stiles, 11-14-2006 16:33:25
Hi John,
Have you checked the internal timing of the magneto? See here for complete B magneto timing information, both internal and assembly to the tractor.
third party image Rod
