Engine part D-17 Diesel
Lester Lawson
11-14-2006 06:13:10
Does anyone know where I might locate a tubing Assy, fuel overflow?. used in the fuel injection system.The part # in the D-17 parts manual is 4510774.
Thank You Les
Texas Denny
11-14-2006 07:43:46
 Re: Engine part D-17 Diesel in reply to Lester Lawson, 11-14-2006 06:13:10
Lester, I had a problem with my overflow when I got my D-17. The tubes were not seamless and the rubbers seals could not conform to the tube surface well enough to stop leaks. I bought all of the fittings and soft copper seamless tubing from a hardware store and made a new manifold. I haven't had a leak of any kind in the last 9 years. I suggest soft copper seamless tubing because it is fairly easy to work with and you can use flair fittings. The downside is that it is not easy to get it perfectly straight (appearance). If you can find hard copper seamless tubing, you could use it for the connections between cylinders with compression fittings. You would still need soft copper to go to the tank.
Buying a used assembly might give you what I had which was useless. Every one of these I have seen on D-17's used the seamed tubing. If the seaming is done well, they work fine - I've seen many that do not leak.
