WD45 front seal
vjd
11-13-2006 16:50:39
just done a complete overhaul on a wd45 the front seal is leaking what are some of your thought on what to do about it? IT has run about 10 min. now and about a good big table spoon of oil came out
JMS/MN
11-15-2006 07:04:25
 Re: WD45 front seal in reply to vjd, 11-13-2006 16:50:39
First thoughts are the same as wking. Hard to align now that everything is back together. If the shaft is not grooved, likely poor seal installation. Take off the radiator and front cover. Observe if the seal is bent to one side. Get a new seal, carefully center the front cover so the seal is not misshaped, then tighten bolts. Older seals were better, current plastic ones are thin. Also helps to install two of them. Press them into place, not hammer.
wking
11-13-2006 17:43:55
Did you allow the timing gear plate to align it' self with the new seal? Maybe the crankshaft has a grove worn in it!
