7030 steering quit!!!!!
toms right hand
11-10-2006 19:24:52
Hi
My 7030 steering stopped after a turn - wheel felt as if it locked up but could be turned with a lot of force - felt "bumpy" when being forced and wheels only tried to turn a little! There doesn"t seem to be a end point in either direction. Jacked up the front end and wheels will turn both right & left but takes a lot of force on the wheel. Any Ideas????
Thanks Pete
Gordon Chance
11-12-2006 16:25:47
 Re: 7030 steering quit!!!!! in reply to toms right hand man, 11-10-2006 19:24:52
There are several things that can cause the sudden loss of steering. The most likely are a bad or crushed left hand differential filter that will close the anti-check drain valve in the filter housing and block the flow of oil to the steering gear pump. The next likely cause is a broken spring in the priority flow valve on the gear pump which will let most of the oil go to the secondary flow instead of to the steering orbitrol. If steering is the only function affected, then these are the most likely causes. If you have lost all or some of the other hydraulic functions, then you are looking at drive train problems in the pump drive. Good luck.
Gordon
Will Herring
11-10-2006 21:08:55
I assume it has power steering? Sounds to me like it suddenly went out and all your fluid went out.
