A.C. WD-45 hyd ram lift cylinders leaking at seals
Deadstick
11-08-2006 13:38:48
My hydraulic ram lift cylinders are leaking badly, and I want to replace the seals and understand that they use some sort of packing material. Does anyone have a supplier for this packing material or a reliable substitute? Any help is greatly appreciated.
Bud H
11-12-2006 06:38:03
 Re: A.C. WD-45 hyd ram lift cylinders leaking at s in reply to Deadstick, 11-08-2006 13:38:48
I just bought 2 sets of packing for my WD at AGCO for $24 each.
acnky
11-08-2006 16:05:09
Standard size V-pack. I forget actual sizes but part # is rod diameter by inside tube diameter. example 1 1/4 by 1 3/4.check size and call local hydraulic supplier.
Deadstick
11-09-2006 13:46:59
 Re: A.C. WD-45 hyd ram lift cylinders leaking at s in reply to acnky, 11-08-2006 16:05:09
Thanks so much for the information.
