Problem with our 180
Isaiah Jones
11-07-2006 15:43:52
This past weekend my dad was using our 180 and the bolt that was holding the trottle linkage to the carb came off. With this the rpm shot up real high he said and he had a hard time turning the tractor off. So last night I put the linkage back on and started it up and the rpms were higher then they are normally. I had the trottle pulled all the way to me and it was still around 1100rpms. Today I started the tractor and it ran normal with the trottle pulled all the way back, but when I pushed about a inch foward it went to 2500 rpms. I talked to my dad tonight and he said there could be something wrong with the govener. So if anyone has some helpful info please let me know. Thank you!
Kent of SW MO
11-08-2006 06:40:13
 Re: Problem with our 180 in reply to Isaiah Jones, 11-07-2006 15:43:52
You need to get a service manuel and readjust your throttle linkage and govener.
Kent
Isaiah Jones
11-07-2006 15:48:44
Also I would like to correct the part about pushing the trottle foward an inch, that it probily wasn"t even a 1/2 inch that it was pushed foward. I would like to say thanks again to anyone that helps.
