a-b sickle mower
patsublett
11-06-2006 18:16:12
Has anyone ever insalled an Allis A-B sickle mower on a model CA tractor? If it's possible, whats involved?
old
11-06-2006 19:13:32
 Re: a-b sickle mower in reply to patsublett, 11-06-2006 18:16:12
Well since I have only seen one CA before, I can only guess but I would think it would mount to it. I know the CA is very close to the B/C in size etc. If you want a manaul for the mower made to fit the B/C drop me an e-mail and I'll send you a copy I have in the computer.
patsublett
11-06-2006 18:17:52
Sorry I ment to say B-C mower
Jerry Coulter
11-06-2006 20:31:11
 Re: a-b sickle mower in reply to patsublett, 11-06-2006 18:17:52
I don't think that the B-C mower will fit a CA, but the #5 mower made for the CA will retrofit the B & C. Keep in mind the C and early B has a smaller spline than the CA and later B for mounting the drive pulley.
Eldon (WA)
11-07-2006 20:07:10
 Re: a-b sickle mower in reply to Jerry Coulter, 11-06-2006 20:31:11
Jerry the late model B's (I think it was the years of the CA) had the larger pto shaft. I think the mower could be made to fit, but the pulleys would have to be swapped, front brackets cut and offset to the front a couple of inches and some rear brackets made to go to the rear drop axles instead of the drawbar (unless it was a pin hitch drawbar or a C drawbar was installed). I have not seen very many #5 mowers set up for a CA around here, but I did get one on an auction a couple of years ago.
