WD allis hand clutch and tranny questions
VB
11-04-2006 15:44:54
When I start off in any gear it seems like there is something stiff/sticking in the gears (kinda like I have a brake dragging, but if you ask me..more like no fluids on a dry gear). But once I get rolling there is no problem and it turns freely. If I use the hand clutch there is no problem at all...only when I use the foot clutch does this seem to happen. When I come to a stop and push in on the foot clutch...just before it rolls to a stop it seems to whant to lock down again...it is not a hard lock down but enough to keep it stiff. Any thoughts? I just drained and changed all the tranny fluids (17 quarts), but it is still doing it...maybe the fluids are not getting to the gears that are inside the hub of its wheels?? Could that be it? Email me if you have any thoughts. Thanks VB
VB
11-04-2006 18:56:40
 Re: WD allis hand clutch and tranny questions in reply to VB, 11-04-2006 15:44:54
Hey...the problem did seem to cure by adjusting the hydraulic control system. When the lift is down it is perfect...after some adjustment it looks like I am out of the woods.
Thanks all for your help.
VB
streaker
11-04-2006 13:29:09
Our WD had sort of the same sympotoms before the pinion bearing "piled up" and cracked the internal housing. Not saying that is what yours is, but something to think about..... .
Will Herring
11-04-2006 16:49:09
 Re: WD allis hand clutch and tranny questions in reply to streaker, 11-04-2006 13:29:09
Would you like to explain this in more detail? It sounds quite dangerous and expensive to fix.
Texas Denny
11-04-2006 10:23:13
I'm with Love-em-all. Sounds like your lift lever is up. May be an adjustment issue.
love-em-all
11-05-2006 05:43:00
Could be just the lift pump. Only time I notice it on my WD is if I have an impliment raised on the arms. The pump is a piston pump and as you start to move the pump starts to compress. Try it with the lift lever in down position and you might check if the lift control is set for normal use. directions on side of battery box or in manual.
mmidlam
11-05-2006 03:20:29
Do you mean there is something sucking power at first? or seems to just be slipping? If so, the hand clutch might be slipping.
VB
11-05-2006 05:46:06
 Re: WD allis hand clutch and tranny questions in reply to mmidlam, 11-05-2006 03:20:29
No slipping, and no noise ....kinda like going up a hill on a rollar coaster...or push starting a car with a manual transmission with the clutch out...except no noise...just a binding till it gets rolling.
Hope this helps explain a little more.
VB
Will Herring
11-05-2006 00:05:01
Is it kind of like on my tractor that when you release the clutch, you hear a "popping" sound before the tractor moves forward initially?
old
11-04-2006 18:26:17
Thorw out bearing for the clutch maybe going bad and causes it to lock up. If its bad it will do that sort of thing and also take out the preassure plate at the same time
