5040 doubts
Chris Cash
11-02-2006 13:31:58
I just bought an Allis 5040 from a local dealership. Its in really good shape and runs well. It has 2000 hrs on it. I got it and the six foot Howse bushhog that was behind it for $3500. But I have gone online and started looking to see how available parts are and have not had much luck. All I have been able to find parts for is the older Allis models. Is this a hard tractor to get parts for or is it easier for the dealership to get them? I've run into companies like Sparex for my Ferguson TE-20. They only sell to dealers. Did I make a mistake buying this tractor or is it not as bad as it looks?
Dwayne TX
11-14-2006 11:48:05
 Re: 5040 doubts in reply to Chris Cash, 11-02-2006 13:31:58
If it says made in Romania, a Long tractor should be its counterpart. Not sure which model.
dairyman
11-06-2006 07:41:34
forgot to say that there is a tag on mine that says made in Romania and all of the parts on it are metric.
cadet trooper
11-03-2006 14:53:23
OK, the 5040 was not a Fiat tractor at least the ones I sold. They, if my memory serves me right they were a Bulgarian tractor, the engine was manufactured by a company by the name of Uzina Tractorul. They were totally different from the Fiat 5050. With the worldwide net I would think someone in Europe can possibly help you out, my suggestion would be to post on this website the Tractorul headline and you may get a response and you may get some White tractor people because they were working hand in hand with AC about that time.Good Luck CT
Chris Cash
11-04-2006 13:31:44
 Re: 5040 doubts in reply to cadet trooper, 11-03-2006 14:53:23
Thanks, i'll give it a try. I have noticed that the hood panels and others parts fit like three or four different tractors. I just don't know what models to compare to.
dairyman
11-02-2006 18:20:19
another good source of parts for these tractors is Wellerts AC parts phone number is 330-262-6991 they are located in West Salem Ohio but will ship parts anywhere.
Chris Cash
11-03-2006 11:44:37
 Re: 5040 doubts in reply to dairyman, 11-02-2006 18:20:19
Thank you for the help. Is there anyone on here that could share whether they have injoyed this tractor? And if so or not what were the good and bad points?
dairyman
11-06-2006 07:39:05
 Re: 5040 doubts in reply to Chris Cash, 11-03-2006 11:44:37
i use mine for loader work and doing utulity work on the farm. it has proven to be a very dependable tractor and user friendly. mine has the 9 speed transmission which works great for pto work beacuse ou can match the ground speed for about anything that you are doing. the only drawback i see is the two stage clutch that it uses to control the trans. and pto because it takes a while for the pto to engage.
klf
11-02-2006 16:25:45
Some of the parts for that tractor are hard to find aftermarket wise. Most of the parts should be available from AGCO. There are a lot more aftermarket parts available than what there used to be. Sparex for example has a very large selection of parts for the Fiat tractors. You will probably find more if you look under 2-50 White or 1265 Oliver. Was there anything in particular you were looking for?
Chris Cash
11-02-2006 16:34:25
 Re: 5040 doubts in reply to klf, 11-02-2006 16:25:45
The gauges look to be shot. I wanted to install new gauges and if the sending unit isn't working then maybe that too. I have never owned a tractor with a working fuel gauge. I was hoping to rememdy this. Also, the tractor is leaking powersteering fluid. I will need to replace these seals.
klf
11-02-2006 16:52:50
 Re: 5040 doubts in reply to Chris Cash, 11-02-2006 16:34:25
You need to try to narrow your propblem down to the sending unit or the fuel gauge. I will check and see if Sparex has either one. You might be able to get a seal kit from AGCO for your powersteering cylinder. I will let you know.
