WD45 Clutch
John wd45
10-31-2006 12:17:53
The clutch on my WD45 is slipping. It will pull in 1st and 2nd. But slipps in 3rd and 4th. How difficult is it to install a new clutch and where can I get the information I need to do this job? Also I need new brake pads. Is this a fairly easy job to replace them? Thanks, I need all the help I can get. JOHN
Will Herring
11-01-2006 15:15:16
 Re: WD45 Clutch in reply to John wd45, 10-31-2006 12:17:53
Just so you know, the new brake pads just get riveted to the old ones... I believe.
As for the clutch, I think both of mine are a bit "loose"... But unsure how to tighten them up.
JMS/MN
11-01-2006 18:25:24
 Re: WD45 Clutch in reply to Will Herring, 11-01-2006 15:15:16
The hand clutch should have some 'snap' to it. To adjust, remove the battery box, and the cover underneath it. Hand clutch has 3 sets of brass shims where it bolts together. Remove equal number of shims from each location to adjust. Shims are slotted- loosen bolts and pull shims. No need to remove bolts and drop them into the oil.
Will Herring
11-01-2006 20:04:47
 Re: WD45 Clutch in reply to JMS/MN, 11-01-2006 18:25:24
I don't know what it is, but my tractor is just hard to shift. It's like I have to throw both clutches, and even then I can still knock the gears after waiting for them to wind down. I don't know what it is.
But the hand clutch does have some good snap to it, I think.
JMS/MN
11-04-2006 08:00:03
 Re: WD45 Clutch in reply to Will Herring, 11-01-2006 20:04:47
Then the foot clutch is either out of adjustment or is about worn out. Linkage is not separating the disc from the flywheel, so it keeps turning some.
Tramway Guy
11-01-2006 07:09:13
Which clutch is slipping??? If it is the hand clutch, it may just need adjustment.
To tell which one it is, have somebody watch the PTO to see if it is still turning when the clutch is 'slipping'. If the PTO turns normally while the slipping condition exists, then it is the hand [transmission] clutch with the problem.
B W inmo
10-31-2006 17:07:56
I would hate to say howmany brakes I have worked on in WD45's and never pulled the axle housing . You pull the pin out at the bottom, unhook two springs, unscrew the linkage rod that goes to pedal, take cover off on top , take tighting nut off on top ,then they should slip out the top one half at a time.
JMS/MN
10-31-2006 20:38:00
 Re: WD45 Clutch in reply to B W inmo, 10-31-2006 17:07:56
I think old is thinking about the Series III and IV D17 regarding pulling final drives. WD, WD45, and first two Series of D17 had the same (band) brake system. III and IV had the band/disc setup, like the F2 Gleaner combine.
JMS/MN
10-31-2006 17:02:22
You don't need to pull axles off the WD45 to replace brake bands. They are replaced through the top side of the differential, accessed by removing covers that bolt on the top. Biggest headache would be to pull the 3/4 inch pins on the bottom side- plenty of stories in archives about the way to pull them.
old
10-31-2006 12:49:12
First you should get an I-T manual if you don't have one. To replace the clutch you need to pull the engine out. Not to bad a job if you have an engine hoist. I can do one in a day or so but I also have all the tools to do it. The brakes you have to pull the alxe houseing off to get to them and thats another day or so of work
