Vernell - this is common on Allis D17 Series IV/170/175/180/185 tractors. If you can't get them to go down except with the tractor off, you probably have a sticking traction booster valve. First push the Position lever and TB levers all the way forward (those two back levers on the right). Next check to see if the TB engagment finger is pushing the TB valve open. Here's a view of the TV valve and engagement finger from top, at seat base level:
Here's a view from the bottom. I had the luxury of taking this shot with the right fender and heavy fender backing plate off:
As you see in the picture, to unstick mine, I loosened the pivot nut then added a 2nd nut to keep them from coming off. If your pivot point is rusted really bad, you may have to take it apart more and clean up the rust/lube the pivot point to get it unstuck. If you found the valve sticking, then freeing it up should let you lower the arms with the tractor running with you standing on the arms. Even after that's fixed, it's still normal for the arms to raise back up on their own without any weight when running the tractor. To cure that probably requireds a full overhaul of seals, etc. in the hydraulic valve stack which is more money & time. Just depends on how much keeping the arms down is worth. Good luck! Mike
